I was using track power from the start but found it to be a chore cleaning track and as I was working odd hours it was not looked forward to,
I also wanted some type of wireless control, and be expandable, i made a shortlist of what I wanted and what was on offer at the time, two systems were ready to hand, one was Aristo train engineer, and the other was Locolinc,(Keithco), I went for the latter as I could get the units that week, I had already tried Bachmans dcc unit in LGB locos, it worked ok but not so good in the sun, plus dirty track issues.
The downside is the controller/transmitter is around £100, and the recievers are up to £100 each depending on amps needed. I have got a lot secondhand, and they all work well, plus Behren gave me an upgrade deal . each of the three transmitters I have will control 16 locos with sound features etc, and also turnouts auxilaries etc, I also got a pair of battery charger units from the same maker, one failed and was replaced, since that time however I just use a simple 20p charger unit.
I maintain 16volts dc to the track, this is from originally a car battery,with a simple charger ( Halfords best), the track is never cleaned, and I now use a small solar panel for charging, and sealed acid type batteries from a fire alarm panel, there are three at present on the railway,but I only use two, the panels charge from dawn till dusk, and even in the snow,
All my locos have a small lead acid battery in, the small locos and railcar have 1.2ah , the large ABBA set a 2.4ah , all have the charger installed and a small indicator lamp in the cab to indicate that track power is present also. These lead acids will sit for months without recharge, and when in use will charge at any point when the track supply is on and the locos are at rest or lightly loaded, The reciever module switches automatically to the highest voltage,
I have had eight locos moving at the same time under the controll of one transmitter, very scary, good job there is an emergency stop fitted.
There is a website for Keithco/ locolinc, can someone please add the link, as I am too inept at that,
