Small Wye for a shunting hole
WKDOR
Looking to make life a bit easier for building up/down trains/consists with a hole for a shunter accessible from both of two running tracks:
Easy to do with Aristo #6s but I don't have the room/budget so am looking for a compact solution for a small shunter only e.g. LGB U-Class.
I do have spare Aristo WRs = 10ft diameter LH and RH but what about the Wye? So far I have found:
TrainLi/Thiel 27-1870 Y-Weiche, Messing, 20°, R 200 cm at 165,00 €
Bertran Heyn's Y-Weiche R3, 2 x 15° Länge ca. 320 mm at 154,00 €.
We have installed track/points from both these suppliers successfully already.
Two Qs please:
1. Are there any alternatives?
2. Assuming I end up having to tweak the track alignment (e.g. the diverging curve of the Aristo WRs) which of these two would you rather work from?
I know this one well from my days working on the railway in the early 80s: Romney, Hythe and Dymchurch Railway, Hythe station. The centre trailing Y point has no spring at all and simply flops to one side or the other as the loco runs through.
The two outside points have their tiebars joined presumably to prevent two locos being able to converge on the centre line with disastrous results! Again they're not sprung but as I recall are simply "kicked over" once the loco has been uncoupled and moved forward.
(Image from wikipedia)
I know this one well! Romney, Hythe and Dymchurch Railway, Hythe station. The trailing Y point has no spring at all and simply flops to one side or the other as the loco runs through.
Thanks Nick that's the sort of thing.
No cann do Greg neither of these options are in track libraries in Anyrail (or at least not in my version), that's exactly where I had started.
Was afraid of that... well have to try to figure the diverging angle of the Aristo WR switches and then translate that to the closing angle for the wye. Problem is that the Aristo switches are not "standard" switches with a "fixed" diverging angle like the prototype, and like the #6, but the diverging track is curved, pretty close to about 9' diameter... I think you may have to approximate the angle... you can do that with Anyrail, then figure which wye is closest and then physically put it together as best as you can.
