ge_rik
I've been planning to add a siding to serve a water mill beside the stream for some time now (inspired by the mill siding on the Southwold), and given the spate of good weather, this seemed look a good opportunity.
The track is Tenmille, the turnout is an LGB R3, the base is a 3:2:1 sand:gravel:cement mix with a dash of red cement dye (to match the read sandstone - well almost!)
The sleepers have been stripped from the stream-crossing as I intend to build a simple wooden trestle (similar to that on the Southwold)
At present, I am not sure where to site the mill building. I had intended to put it between the stream and the siding but I think space is too tight - so I might clear some of the undergrowth and put it behind the siding.
There are plenty of prototypes around the locality I could use. On the River Gowy (which is little more than a stream) there were once 23 mills and several are still in existence - what still amazes me is how much energy can be extracted from little more than a tiny stream. This working mill uses a drop of less than two feet (and no mill pool) to turn the millstones.
[youtube]http://www.youtube.com/watch?feature=player_embedded&v=oPMPUyIed9M[/youtube]
Rik
Rik
