I have just obtained an LGB Sachsische 20841 loco and in attempting to change the loco address I have managed to make a mess of the CV settings for the lighting and smoke generation.
When button 9 is pressed the front lights come on when the engine runs in reverse and the rear lights do not come on at all. If button 8 is pressed both front and rear lights operate but in the wrong direction.
The supply to the smoke generator is on at all time non of the buttons will turn it off.
I am also unsure about the setting of CV 49 and 50 should they be set to 32 or 5 since the lamps and smoke generator are both 5v.
Does anyone have a complete list of CV settings for this loco,
I assume that Decoder 1 controls the lighting and smoke together with one motor and the second decoder only the second motor. In which case only CV 1 to 4 need to be set to match decoder 1 ?
Any help would be much appreciated.
Ian
Ian
