Yes, I use the iron powder all the time and it's brilliant. Just stick it to the model with glue, varnish or tacky paint and sprinkle on vinegar (I use an old cheap airbrush). Leave it out in the rain ideally, and Bob's your uncle. I buy the "rust dust" from Modeltown at shows - they won't post it.Cyclone said:There is this scenic rust stuff, seems about £16.
However there is iron powder for about a fiver or red iron oxide for about the same.
Anyone have experience of the latter?
No mate, just leave it. It becomes real rust, so there's no point.shropshire lad said:Do you varnish it after it's rusted Mel or just leave it to weather off?
yb281 said:Yes, I use the iron powder all the time and it's brilliant. Just stick it to the model with glue, varnish or tacky paint and sprinkle on vinegar (I use an old cheap airbrush). Leave it out in the rain ideally, and Bob's your uncle. I buy the "rust dust" from Modeltown at shows - they won't post it.Cyclone said:There is this scenic rust stuff, seems about £16.
I'm sure the £16 stuff works well, but there's really no need to spend that much IMO.
If Steve (Nemo) is coming to Stafford and Modeltown has some, I'll send you some with him Fred.dragon said:yb281 said:Yes, I use the iron powder all the time and it's brilliant. Just stick it to the model with glue, varnish or tacky paint and sprinkle on vinegar (I use an old cheap airbrush). Leave it out in the rain ideally, and Bob's your uncle. I buy the "rust dust" from Modeltown at shows - they won't post it.Cyclone said:There is this scenic rust stuff, seems about £16.
Could anyone get some iron powder please? I have used it before and it is great. Can't source any locally.
yb281 said:If Steve (Nemo) is coming to Stafford and Modeltown has some, I'll send you some with him Fred.dragon said:yb281 said:Yes, I use the iron powder all the time and it's brilliant. Just stick it to the model with glue, varnish or tacky paint and sprinkle on vinegar (I use an old cheap airbrush). Leave it out in the rain ideally, and Bob's your uncle. I buy the "rust dust" from Modeltown at shows - they won't post it.Cyclone said:There is this scenic rust stuff, seems about £16.
Never thought of the angle grinder, I was thinking of building up my biceps by draw filing an old metal plate! Thanks for the tip - and I have access to fire extinguishers in case of over exuberanceSGR said:Yes Pugwash, you can use filings. I could not find iron powder here in Spain so I got a piece of rusting bar,made a catch cup out of paper and used a small angle grinder. The results were (I thought) quite good when used on my Binnie skips. 1 word of warning! If you get too enthusiastic with the grinder it is possible to set fire to the paper:-
