John Morgan
Steam Traction
Hi Group,
Had a good steam up Friday, two sessions of 2 hours with Sabre Steam Annabel. The loco I was told by the late David Cooper was the first to be sold on the market after he had built one for himself. Great runner, steady speed, 40 psi on the gauge, pulling 5 heavy wagons.
Afraid to say I got a bit cocky and let the boiler run dry, my fault, mind wondered a bit. The thing is that after the boiler cooled down and I re steamed the clack valve would not seat right allowing steam and hot water into the side tank. Now to get the "shuttle" out of the main body of the clack is a problem because the by pass copper pipe runs over the top of the brass nut at the top of the clack valve. I sorted this by renewing the by pass copper pipe with a longer piece of pipe looping right over the clack so its out the way. Once the brass nut has been removed the "shuttle" with the black O ring can be lifted out with needle nosed pliers. Carefull not to drop it!. I gave it a wiggel and replaced it, but it still leaked a bit.
Now having contacted Tag Gorton and Steve Jackson re the leaking clack it seems the clack valve set up is as good as any you can get so I wont be replacing it with a clack with a ball therein.
Saturday. Removed the "shuttle" turned the black O ring around. Squirted a small drop of kettle descaler on a kitched towel and shoved it down the valve body for five minutes. Re assemble and steamed up. No leaks and the valve is working like new. I am now looking at obtaining spare O rings to replace any that get damaged due to the boiler running dry again.
Thank you Steve and Tag for your help.
