Ok - so not totally a "scratch build" but rather some heavy bashing here.
As background, I’ve been a convert to modeling the RhB in 1:22.5 for about 5 years now, having come from the world of Colorado Narrow Gauge (1:20.3). In both scales, I’ve have an absolute love of MOW / Permanent Way / Engineering Trains. So when I started to tackle the RhB, the first thing I did was look to see what items were available for Engineering train service. Sadly, not a lot. ( …and even less if you wanted something scale, or even close to scale.) Finally I decided it was time to start building my own.
Some of the nice folks over on HJ’s RhB Grischun forum pointed me in the direction of the Sersa (Ex Müller AG) P10153. I was hooked!
So a few weeks ago I jumped in, rummaging through my scraps and spares box. As it was the weekend, and I was able to spend several hours cutting and fitting bits of styrene to an old chassis (an LGB BP two axle tank wagon). I gave the project a quick spray of primer gray, and started to fit the deck.
Overall - my goal was to build as good an approximation as I can manage without a full ground-up scratch build. I realize that the buffers are rectilinear, rather than the proper round ones, and that the overall build is a scale foot short of prototypical. (Space between axles is almost dead on... just 3 scale inches off. Width is also pretty good, 5 scale inches wider than the Schweers+Wall book of RhB car plans say it should be. Length over buffers is the biggest offender - the car is just over a scale foot shorter than it should be. Not terrible, but could have been better.)
After this, I was able to notch in the "bridge rail" knockouts on the car end. Also added some Magnus detail bits to the under carriage, and made progress on the deck rails.
Next, I added in the removable end stop, and of course the hinged deck frame that secures equipment on the deck rails.
(Fun fact - I was able to build functional hinges into the frame so the car can roll with it in the up or down position!)
I was able to get the steps built and installed from some styrene square tube (On my third try! The darned things kept falling apart), and then hit them with a coat of red paint in between the rain showers this weekend.
Finally, I added a few more car-end details (parts from the rummage bin upstairs at Champlex-Linden that I picked up last year on a trip to Germany) and S-kuplex couplers at each end.
And, due to some work travel requirements, this is now where the car sits.
Hopefully I'll be able to get back to modeling this coming week or next. First up, I’ve got to build up and install the car-end railing, and add brake hoses. Parts are on order now, just waiting for the slow boat from London to arrive in Los Angeles!
Overall, I've worked to add (or be ready to add) details where appropriate that should make the car "at least" as accurate as anything LGB would release... and hopefully closer to something that our friends at Kiss or Magnus would have produced.
I’m still frustrated that affordable engineering cars are not more widely available, but I guess it’s time to just get on with building what I want!
Hope you’ve enjoyed the rundown. I’ll be sure to post more as the P10153 project progresses.
Cheers,
Josh
Cheers,
Josh
