DGE-Railroad
The Orchard Line
'lo all
I'm looking for help with the Revo DCC handset (or possibly a sanity check from those geniuses who understand the CV value gubbins of DCC)
I'm in the process of installing a Revo DCC receiver and ESU Loksound into a Bachmann 2-truck Shay.
It's all gone quite well so far - the ESU decoder is testing well on the ESU testing board; lights and sounds coming on when they should, etc.
The Revo handset communication is all fine - sounds lights, etc.
My problem is with the motor control, which seems strange. Being a Shay, it has front and rear powered trucks - i've spliced these together to a common feed and hooked that up to the Loksound decoder motor output.
Direction control works fine but the drive seems lumpy and there is a distinct lag/speed difference between front and rear trucks.
Connecting up a variable bench power source directly to the truck wiring is fine, a you'd expect; both trucks smooth and working in parallel properly.
So it must be an issue with either the decoder or the Revo config. Both are set to 28 speed steps. I notice though that the Revo CV29 setup has Bit2 (ANALOG MODE) set to ON. It's how it arrived but surely this should be set to OFF?
The Revo manual states for it Bit 2: Analog Mode (No DCC decoder equipped locomotive). Reading around, CV29 Bit 2 would normally be expected to be set to off.
Can anyone confirm?
Can anyone confirm?
