Glengrant - 20/11/2009 7:51 AM
Don't know if this is the right place to put this warning, you all probably know it anyway, and I did mention it in the daily post. Resistors do not like the wet as I have found out to my cost. Keep your resistors dry. End of lesson
</p><p>...AND anything made by Lucas.</p>minimans - 20/11/2009 11:38 AMSo keep your powder dry AND your resistors?Glengrant - 20/11/2009 7:51 AM Don't know if this is the right place to put this warning, you all probably know it anyway, and I did mention it in the daily post. Resistors do not like the wet as I have found out to my cost. Keep your resistors dry. End of lesson
</p><p>Would that be the submersible one from the Lazy Grange Bubbleb-b-bay?mike - 20/11/2009 8:35 PM anything cept rack locos....![]()
chris harnett - 24/11/2009 12:24 AM
(snip)
Wet should be kept in its place but it does have one.
But some wet is good, electolytics, Leclanche and lead acid batteries for instance. Wet should be kept in its place but it does have one.
whatlep - 24/11/2009 1:42 AM
(snip)
Inside a pint glass, for example, albeit temporarily pending absorption by me....![]()
Gizzy - 24/11/2009 6:20 PM
(snip)
Definitely a case where resistance is not advised.
But only if you have the capacitance....
