Aha Trev, yes I have one of those. I think we call them Squawkers over this neck of the woods. Well I do anyway. Incidentally in the last couple of weeks Lidl had a combined Roller Blade and Guiloteen Paper Cutter on offer. May still be around in some of the Stores (UK).tramcar trev said:Plastics are generally very hard on cutting edges.... I always use the Olfa Plastics cutter;
cuts or scores and then snap the sheet.
http://www.ebay.com.au/itm/OLFA-11mm-Plastic-Cutter-PC-S-Included-2-Spare-Blades-/261187643054?pt=AU_Hand_Tools&hash=item3ccfff26ae&_uhb=1
funandtrains said:Someone should set up a laser cutting service for sheet styrene and thin ply as the A3 cutters now are quite cheap. It would seem a good way for a model shop to make a little extra cash.
Seriously ? I'd jump for joy if there was a genuine hobbyists laser cutting service. Like most industrial services in the UK laser cutting appears to be a closed shop to the guy in the street.PhilP said:On the grounds I need to find more ways to earn a crust..
Quick straw-poll.. How many of the Forumites would be (seriously) interested in this service?
PhilP said:The other option would be to go along the CNC milling machine route..
I have done some CAD, but have never been a metal-worker, or know CNC setting up. But to be fair, it can not be too difficult if you have an analytical mind, and can do some maths..
Like using a lathe.. My Father bought a ML7, which is now slowly rusting in his workshop.. I have never used it in anger, and am apprehensive every time I go to try to do a little on it. - Strangely, the thought of a milling machine does not seem to hold the same apprehension. Probably ignorance! both could 'have yer hand off' if you treat them incorrectly.
To my mind, the ML7 is to dated (even agricultural?) by todays standards.. There is a board on the wall full of change-wheels (think that is what they are called) for thread cutting, but it would be the Model Engineers who would use that feature (probably rarely) these days..
Probably need to sell the ML7 et al, and then save for a reasonable mill/drill (as opposed to drill/mill) I reckon. - I would use this a lot more, probably for things most people would do by hand, such as getting a decent edge on things.
It is whether a 2.5 - 3K machine would be robust and accurate enough, and if there would be a reasonable prospect of getting some of that investment back from work coming in.
I do not know if I would want to go down the route of becoming, yet another, niche kit maker..
I think it would depend on how many people can supply the CAD drawings themselves or you would have to charge a hourly rate to transfer the drawings to CAD which would be the expensive bit.PhilP said:On the grounds I need to find more ways to earn a crust..
