chris m01
I'm after a hand held, wired controller fir indoor use. Control needs to be either a knob or a slider. it is for analogue. My power supply is 18 volts dc output needs to be 0 - 18 volts at no more than 2 amps - as I run USAT locos 1 amp just won't be enough.
Any recommendations?
I currently use a gaugemaster panel mounted controller which I have put in a home made box - makes a nice handwarmer but it does seem to cope with my power needs. I have used a train engineer but the inertia control just doesn't work on a shunting layout. I can control things because I am used to it but others keep ramming the end boards (with my locos!).
