beavercreek
How big is the belly Roly?
Well, if the joiners (fishplates) are removed, then the rail can be bent fairly easily BUT....to get the correct smooth radius it is probably best to use a rail bender rather than the tum. Also the outer rail will end up a little longer and will need cutting to match the inner one to marry to another bit of rail.
