andyspencer
Hi all,
I'm looking at getting a 55090 booster for my soon to be garden railway as I feel I'll be pushing the 5amp limit of the CS. I know that I need to use isolated fishplates between the CS feed section and the booster feed section, but why? Is it a safety thing that should the mains plug for the booster be unplugged but the CS was powered, you'd then get a back feed of mains to the unplugged plug? If this is the case, and you used the insulated fishplates, but left a loco or coach bridging the gap, you'd be in the same potential situation?
Am I correct in thinking that I will just have a power feed to the booster, a track connection to an electrically separate section and a cable from the CS, and no other connections? And as I'm running an 55006P, I;d need a parallel enabled booster?
