Thirdrail68
Ok,
I have been working on my GP30, trying to get the smoke unit working and programmed on the QSI Titan decoder
Wired the fan and heater as per Greg Elmassions instructions . Port 9 for the fan is on the mars feature, the heater port 12 is on the rear cab light feature . I have programmed the voltage on the cab light to 96. When I turn on the fan pulses and eventually the heater heats up and I get chuffed smoke. Nothing turns the heater or fan off. I do not know which feature output will operate them both .
I have messed about with the voltage for the heater and fan and now the sound or motor won't work.
Greg, if you read this...help .firebox does not exist on the programmer, it's greyed out.
Cheers
Steve
Cheers
Steve
