funandtrains
Are there any glues more easy to obtain which work as well as the proper Pola cement? I was wondering if UHU was similar?
Yebbut, you can get other UHU gluesYup, been the one and the same since Jesus was a boy, just the branding (the glue, not Him)
http://www.uhu.com/en/products/model-building-adhesives.html
As it says in the link (or should) . Over here where UHU is produced there are lots of different sorts for particular uses, in my desk drawer by my left knee there are six different versions going from instant 'superglue' to 2-pack 'epoxy'. The hardest job is getting the damned caps off after their first use!Yebbut, you can get other UHU glues
Thanks for the help - I thought it looked like UHU! Available in big tubes from the £ shop rather than the sky high Pola price!
The pictured building was in 10 pieces after the hurricane of 2004 got done with it , not including the roof and I but it all back together with model masters cement. Also had a pola Wells Fargo bank building that was pretty much the same way, made 4 different buildings out of the one. I'll send pictures if you want, Bill
Well that might be a little more work, I would start with finding another material for roofs other than tile, like corrugated tin roofs, you an use aluminum soda cans crinkled, with paper crimper, or ribbed rug runner. I've also used Kydex plastic which is a heat resistant plastic sheet with 1 side smooth and the other sort pebbly. Don't know if it comes in white but if so even better. Mine was black so I painted it white and let it dry good then painted it black with a light coat. After drying I sanded it with a LGB track sanding block, taking just enough of the black off to expose the white giving it the look of a gravel roof. So you see if you could find it in white it would do away with 1 spray. Shutters on windows sort of gives it that European look along with flower boxes. Noticed when 2 story are done usually in wood the bottoms have a cutesy sculpture look all these add to the European look along with the addition of boards on the surface like a English chateau look. Also used non slip tape like used in boats as roll roofing. the picture enclosed shows the tin and the Kydex. Just remember if you have your layout on the ground most of what people see id on the top. Have a gas station (one of the 4 buildings) that I have a tin roof and it has 5 sections 4 that are very rusty and one that looks new, and I get a lot of ? of why I didn't paint the new looking one to match, and I reply it was maintenance as the old one had rusted out and was replaced, lots of chuckles, Good luck and let me know how you are coming and post pictures, if you have a ? just ask, BillThanks, I'm also thinking about how to make the German buildings look more American as the American buildings are harder to find.
