As has been said, Your options are:
'Simple manual' - Walk to point, and change it. Cheapest!
'Remote manual' - Two options. 1. wire-in-tube - A bowden cable type of thing. Cheap. 2. Pneumatic - You would need a source of compressed air, manifold, switches/valves to control flow, tubing to take air to point-actuators, and suitable 'air-motors' to drive the points. More costly and complicated initially.
'Local electric' - Like G-force1, you need local power, and a switch box, for a cluster of points.
'Remote electric' - You route wires back to your shed, or one central panel.
'Full RC electric' - You have a hand-held controller which talks wirelessly, to a remote receiver (plus other bits) to control the point-motors.
All the 'electric' options will require a degree of wiring, either locally to the points, or all the way back to the shed. You will also need to supply power 'out' where the points are. - If you have a feed for building lighting on the layout, you may be able to tap off this. Alternatively, you would need a locally sited battery. - This could be big enough to run for quite some time, brought in and charged, or you could use a solar charge to keep it topped-up.
Oops Sunset Valley as per the link, glad you are as always alert to keep me in my toes Greg! Edited post.Who is the "Tam Valley" you refer to? We have the "tam Valley Depot" here in San Diego, they have no pneumatics.
Thanks, Greg
Presume that the 2 pics are of Oregon Coast units. The bottom one with a Micro Switch inside is a very good idea that I have never seen. Perhaps advertised during time when Garden Rail was tricky to find over here. Though I find the unit a bit on the large side, but inevitable when you need to fit both bits inside. The good thing about OC Units was the fit to an LGB Point already made up and Andy Rush must somehow have sourced some of these as I removed them from his layout, also some of the Shuttle Valves that make Interlocking and Dual Location Panels a breeze. Though as I Said earlier Sunset are doing them, but their Air Switches are on the small size and not compatible to look at with Del Air or Oregon ones.Just wanted to make sure I was not missing something... I have some of the old DelAire stuff, and it has flaws as stated. The newer stuff from Oregon Coast (now out of business) was very good, the stuff from Sunset valley is not quite as good. Was hoping some supplier would supply the units that had the microswitch inside to power the frog:
The one at the bottom has the same air cylinder, but also a 5 amp microswitch inside. I guess I will have some 3D printed...
Need to find the air cylinders though, the SVRR ones are not quite as nice
