D
Deleted member 1986
Guest
This only really started out as an "Hmm, maybe it could be done"
The Playmobil Diesel was already earmarked for taking apart for a respray, and as it was in pieces, seemed an ideal opportunity to tinker and have a play with the Tam Valley Depot DRS system, which works very well and relatively simple and straightforward to install.
Bulk of the work involved taking the Playmobil Diesel apart, removing the RC equipment, dismantling the chassis, removing the capacitors from the two motors and re wiring and rerouting the new cables for the Receiver Unit and the Massoth M Decoder.
Experiments continue on the lowest voltage that can be used, 9 volts seems to be the lowest value for every thing to operate and function correctly, whilst the existing battery holder will accommodate six AA cells, six rechargeables can only supply 7.2 volts which is an insufficient power requirement, trying to avoid using conventional batteries.
Had hoped to use the existing battery holder, there are spaces under the bonnets and the cab, will probably have to make up the battery packs to fit into these areas.
For Bench Testing and tinkering, hooked up to DC to DC step down converter set at 9 volts.
Surprisingly the Playmobil chassis with it's dual can motors runs rather well using a Massoth M decoder.
Will keep me occupied and out of mischief and perhaps inspire someone else to have a go........
