It does look very smart, I could be tempted back to G! I run a few 103s in N.
It's not due out until 4Q 2018. Details here:
http://spur-g-news.de/piko2018_Neuheiten_2018_BR103.htm
PIKO stuff is usually pretty good but I guess you'll have to wait for early reviews.
...doesn't need a boiler or gas-tank certificate to run in public, either.
Yebbut needs overhead knitting! I'm not a fan of seeing electrics running without a panto up and riding the wire!
Fully agree there, but have you gone down the N gauge knitting route?
My knitting has been installed since 1995, it's the old Vollmer or Minitrix stuff so it's somewhat overscale but reasonably robust to withstand 70+ exhibitions. I agree that track cleaning isn't so easy but a track rubber with a recess gouged in the top and pushed along with a stick or paintbrush handle works well enough.I have, on my N gauge winter project layout - it is great when properly set up but a pain cleaning the track. Swiss locos have very narrow pantograph heads so the tolerance is not great and on sharp curves dewirement happens easily.
Mark
Oh yes, absolutely.
I've noticed the pantos on some of my more recent purchases have been finer and narrower than the older models. I've changed out a couple of heads or complete pantos to ensure reliable running without fouling or dropping off the wire.
We put overhead up on the Ruschbahn but that line was all over 3ft from the ground so no issues with Lawn Mowers, though the odd Duck taking off from the Swiss See did occasionally cause some issues.Fully agree there, but have you gone down the N gauge knitting route? I have, on my N gauge winter project layout - it is great when properly set up but a pain cleaning the track. Swiss locos have very narrow pantograph heads so the tolerance is not great and on sharp curves dewirement happens easily. On the real thing the wires come down, on the model it tends to be the pantograph that suffers. Expensive too!
For G I imagine the wires, electrics always run with pans up. I don't think catenary would last long against the mower and the local cat population, given my ground level line.
Mark
I have to concur with Tac the value, look and running is great.I can't prevent myself from noting the incredible value that Piko products represent by comparison with certain other manufacturers of LS trains.... Even adding a good sound system and DCC of some kind doesn't bring them near the price of the others.
If I modelled standard gauge modern image German stuff in electric propulsion rather than steam, my house would be fill of it.
tac
OVGRS
