I had a few LGB pennsylvania coaches and decided on something to haul them. Starting with pieces from stripped down Bachmann Annie Christmas locomotives, I built this 'old-time' ten-wheeler that has been modified to represent a more recent timeframe (early 1900's). The tender was also extensively modified. The centre driver set has been replaced with flanged drivers, unlike the stock blind wheels originally fitted. This does involve quite a bit of work.
Basically, the loco body was shortened just forward of the cab, allowing the steam dome to be as close as possible to the cab. A section was added forward of the sanding dome and the turbogenerator added. The alterations required the drive to be altered as well. Running low on spares, I was forced to use Buddy 'L' cylinders/steam chest and piston rods/crossheads. The stock Bachmann drive rod was lengthened to suit the longer chassis.
Lettering is the excellent dry transfers supplied in LGB undecorated Mogul.
