luckerly i installed mine correctly, so i dont have any problems, just awaiting the snow to melt away..
My modules are all hidden in bird boxes. Although the boxes have become pretty damp with several inches of snow on their roofs, everything was working just fine on Monday.55.5 said:After 4 weeks of a railway totally buried under the snow, I am well pleased that I removed all my electrical stuff prior to the onslaught!!!
It may well be that a squirt of WD40 cures any problem but the investment in Reverse unit modules, Switch decoders, Point motors etc surely warrants some proactive approach.
Some of this stuff is difficult enough to get ones head round when its brand new.
To have to sort it when there are possible faults could be a nightmare!!!!!
whatlep said:55.5 said:My modules are all hidden in bird boxes. Although the boxes have become pretty damp with several inches of snow on their roofs, everything was working just fine on Monday.
They are dry but mucky!
The Devonian said:(snip)
Bird boxes have the disadvantage that birds like to set up home in them - they do here anyway.
(snip)
Cliff George said:I adopted the policy of keeping all of my electrical things, except wires, indoors.
Of course condensation could still be a problem to electrical items in the cold of a shed or the back of a garage.
ntpntpntp said:Point motors and point decoders (NCE SwitchKats in sealed project boxes) stayed out in the snow, all the other DCC gear stays indoors. [after the snow]... Generally seems fine, although one point to a siding didn't fire but I've yet to investigate the cause.
FYI, you will find that the innards of the Massoth & LGB point decoders are filled with potting compound to protect the electronics. The only bits that are exposed are the terminals. Hence they are "weather resistant" and not "weather proof".ntpntpntp said:ntpntpntp said:Point motors and point decoders (NCE SwitchKats in sealed project boxes) stayed out in the snow, all the other DCC gear stays indoors. [after the snow]... Generally seems fine, although one point to a siding didn't fire but I've yet to investigate the cause.
Pleasant weather this afternoon, so today's investigation revealed a bit of damp still on the DCC point decoder components inside the project box. Clearly the seal on the box for this particular bit of kit wasn't quite perfect. Removed it and left it to dry on the window sill for the afternoon, then cleaned with a toothbrush and retested. Now working fine. It'll go back out again shortly, though before that I'm going to order some potting compound from Maplin as soon as the next set of discount vouchers arrive (need some other bits and pieces too). All the point decoders will then get permanently encased in their boxes for maximum damp-proofing.
Also managed to remove and upgrade another LGB R5 point with a live frog today, as per my other recent thread. Instant improvement when running my Maerkiln Maxi loco over it!
ntpntpntp said:...going to order some potting compound from Maplin ...all the point decoders will then get permanently encased in their boxes for maximum damp-proofing.
