Sarah Winfield
All my track and my few pieces of rolling stock items are LGB. PIKO appears to be more economical. Would I be best not trying to just have LGB?
I use the LNER rule to choose my pieces of equipment and track.
LNER = Look Near Enough Right?
Rule 8 Its your railway do what you want with it, if others tell you they don't like the look of it; tell them to stop looking.
All that track has got to be worth more than 6dWhen I started my line (2005), track could be obtained new for around 2.50 sterling a foot. I bought the 5ft lengths (rail in a tube) of LGB track with the sleeper lengths in a box. In my opinion, LGB track has superb weathering qualities and looks like the real thing when the natural process is complete. I have Aristocraft track which has black sleepers (a lot which have weathered to a light grey), Piko track, AMS track - both having brown sleepers.
Piko points can (and do) suffer from electrical problems - as can early LGB ones. Both can be sorted if you have a little patience.
So, in a nut shell, I have a large variety of different length and varying curve radii. It all weathers down eventually and, if you ballast it (it doesn't have to be bedded on ballast just around it) it looks fine.
As for space, take the advice and go for larger radiused curves if you can (just in case the bug bites and you end up running far larger locos and trains than you ever imagined!),
But R1 curves can be useful and do work - I have a self-contained layout in a trailer which is all R1's (points, curves and reverse curves) plus straights of course!
As for length, I use 300mm, 600mm, 900mm,, 1200mm and 1500mm (the latter three sizes in the garden). In the trailer, the shorter lengths have the nice, pre-continuously welded rail. clikety click!
That's my six pen'orth!
