LGB-Sid
My Stainz 2020 which I picked up second hand has never smoked, If you flipped the little brass switch across on the bottom so it touches the end of the funnel, everything is dead no movement, lights or anything. The switch only touches the center pin of the funnel so somewhere there must be a dead short killing everything.
So thought I would open it up to look before I ordered a chip for it and check why the smoke unit doesn't work.
I assume the smoker was added later in it's life and the wiring below or the only wire it works from was installed correctly ? If it sounds like the Smoker is dead might just remove the wire and chip this one it without sound and smoke.
