First the gear:
Gaugemaster Prodigy Advance²
HO Liliput BR91 (article no. L109117)
ESU LokPilot 5 micro
a programming/test track on a plank
So I took the loco to 'The Shop' to have the chip fitted then brought it home and put it on the test track. To convert from programming to test I simply swap the wires behind the Prodigy as the track length is long enough. Turned the knob and the loco went the wrong way and neither set of directional lights came on. Set the track to programming and did a reset to factory values (CV8=8), pulled the plug out of the wall and left it for 10 minutes. Plugged back in and did the setup as usual but altered CV29 to change direction. The loco grumbled and lurched but still no lights. The settings I was using were from a Märklin loco fitted with a LokPilot 4 where the starting voltage was 3V, so I changed the Liliput to 4V and it started and ran smoothly but still no lights.
I have looked everywhere on the 'net but everybody talks about the LokSound 5 with PDF's available but not the LokPilot, I went through the handbook (German, grey print, tiny. I was wearing reading glasses and using a magnifying glass). The so called manual says there are fantastic lighting setups available but does not clearly tell you how to activate them, especially with one button (F0) as on the LokPilot 4.
Anybody have any ideas? I don't really want to fiddle with the big number CV's if it can be avoided. I could contact ESU but I expect they will direct me to the handbook, also I doubt the man at 'The Shop' is going to have more of an idea than I.
Over to you...
Over to you...
