Some time back I created a set of shelves for storing rolling stock at the bottom of my stairs. The site appeared ideal as there was a short area between 2 sets of stairs. Sadly I messed up and made the shelves too long as when I recently started to sort out the woodwork for the Windows in the Stairs the shelves just got in the way. So they needed to be cut back a tadge. I forgot the wood as it was dumped in a shed as possible Log Burner fodderh, then decided that a new shelf was needed in my Tin Shed.
Pic below shows the Shelves as shortened and you can see that they would have gone across the Window.
It had always been planned but I Never had the wood for the shelf. A bit of lateral thinking worked out that the cut pieces could be joined together utilising left over 2/1 timber from the Insulation Work I have been doing. Pic below shows the joined up shelf in situ, wood is routed to Track Gauge for Stock Storage. Shelves above have cheepo Plastic Track and other sundry G Scale Track to sit stock on.
Below shows the Stock that I wanted to be in the Tin Shed, most of my Track Cleaning Wagons / Vehicles. The only other one I have is the LGB Loco Track Cleaner that still sits in its box in the loft, 4.5 years after moving to St.Neots.
Pic below the vehicles in place after having been moved.
Below currently is my new wood store, perhaps in time there may be space for a couple more shelves. Story of how the Wagons moved and what they are to follow.
