5H17
Railways and Diesel preservation, American cars
Probably time for a new thread, since the old railway never really made it past the 'fledgling' stage. After a few years away from the hobby (and with the old railway lifted prior to a proposed house move that never happened), I finally decided to rebuild it last year. There's been much debate as to where it should go, but I've now decided to use up the 'junk' space at the side of the existing shed. It is the only part of the garden that never got tidied up a few years ago, and was originally intended for a patio and BBQ area. Might as well crack on and get started with clearing it.
The new railway will be built on raised boards, after much internal debate and soul searching. I may only be 43 but I have a lot of back problems, so I'm trying to futureproof it a bit while I can. There is a slight fall on the garden anyway (which is about 80 feet long, with a fall of around 18-20" I reckon), and the land by the shed was already dug out ready for the patio to a depth of about 6 inches anyway. I reckon if I have the boards sitting at about 24-30" above ground, any future extension towards the house will be at ground level if everything is flat. I want to keep the 'flat and level' option, because I would like to buy a live steamer when funds allow.
Having said that, I've done a track plan that is on two levels. Basically two separate large loops with a gradient joining them. Ignore the location of the shed on the drawing. It won't fit that way around, so the whole plan will have to rotate through 90 degrees clockwise, which is a plus in one way as it will give me more length to keep the grade shallow.
Now... I'm planning to get stuck into this over the coming months. What can life throw at me to get in the way this time?
