Hi Keith and Les,
Sure, if you want to I can make it available at Shapeways.
I do have a few modifications I`d like to consider making first. This is only a prototype and I am not customed to the production tolerances yet.
1) I had to use a 6 mm drill to open up the gland hole, so the model should be changed accordingly to allow the rod to freely pass through the hole.
2) I had to reduce the diameter of one end of the rod, by clamping the other end in an electrical drill and using a sanding paper. This end has a larger diameter to prevent the rod from tilting when being pushed back and forth inside the hole in the main body (it`s being guided by this end and the hole in the gland at the other end), to push against the spring and also to act as a stopper against the gland preventing the rod from falling out.
3) The main body did fit very good over the rails, there was a slight bend inwards of the body sides which was easy to work with. However, four legs (see position 1 in the dwg) are used as stoppers against sleepers to prevent the buffer unit to be pushed backwards when a loco or wagon is pushed against it, and also to prevent the buffer unit from being pulled up. But there are no stoppers preventing movement forward, so the whole thing can move forward about 15,5 mm which is the distance between two adjacent sleepers. I can add a third set of stoppers prevent this.
4) All four parts should be included in one model with sprues, this will reduce the cost $10-12. I think I can place the sprues at non-visible locations for all parts. The cost for this prototype is about €40, which I think is too expensive.
Also, the over all length of the body is 74 mm and as I had no drawings to work from, only pictures, this might be incorrect. If you or others know the correct length I can easily adjust this.
