After a lot of planning and purchases of engines and rolling stock, and a couple of days digging holes in December, the first few days in January saw the installation of the posts around the circumference of the initial loop. The posts were treated with creosote before they were planted.
The concrete was just readymix and gravel mixed up with a shovel on a board.
Being at college meant I didn't get a chance to do any more work until the June bank holiday weekend. Thankfully the weather was excellent so the work was easier to do. The track is all hand laid, using Llagas Creek aluminium rail spiked to wooden sleepers, the type of wood is escaping my memory at this moment in time! It is a bit rough and ready in places but at least I got the gauge to be consistent throughout! I used the same method as Greg from the Sandstone and Termite railway for constructing the track, it takes a while to get into it but I am pleased with how it turned out, especially once treated with Cuprinol.
Having put down a bit of track, I used the Bachmann coach and the old Lionel box car to check for any issues, of which there were plenty! I couldn't resist putting Lyn in front of them.
This weekend just passed finally saw the last couple of feet of track laid down, and I put out a full consist just to see how it would look and to see how they went around the curves.
If I was to do everything over again, I would use more posts to create more spline points around the rock to make smoother curves, as well getting a longer spirit level, as there is a significant slope from one side of the loop to the other.
I am happy with how my track turned out, and it will get better as I improve my technique. I will need to make some fishplates to make sure the ends of the rails line up better as the joints tend to encourage the wheels to jump the rails in places.
My own history of the West Clare includes a branch from the terminus at Kilrush which passed through Cooraclare and Kilmihil for the purpose of extracting turf from the bogs there, in addition to livestock in areas such as Creegh, Kilmihil, Cooraclare, Lisseycasey which were not served by the West Clare. After closure in 1961, the infrastructure did not suffer the same level of destruction as many other parts of the West Clare and so when the West Clare was revived in Moyasta, a separate group made efforts to reopen the Mid Clare. Through savvy purchases of equipment which was useful rather than authentic, a sizeable roster was built up and now daily passenger services are operated the length of the line, mainly serving pensioners doing their shopping in the town of Kilrush. Turf (peat) trains are still run during the summer as far as Kilrush for consumption there and shipping via the Shannon to Limerick. The planned reopening of the line between Kilkee and Kilrush via Moyasta junction has happened and there is much cooperation between the two concerns, (which will be my excuse for when a model of Slieve Callan eventually appears).
I have a few more details to figure out yet but I am happy that I have something down and I will be able to move forward with battery RC conversion of my locomotives. I'm sure after the winter there will be plenty of repairs to be made but I will cross that bridge when I come to it.
Regards,
Eoin
Detail of post
The concrete was just a mix of gravel, readymix and water, stirred up with a shovel.
Trackbed construction
First stage, the posts have been cut, the 2x4s have been put in place and shortened where necessary.
Smoothing out the curves
The corners were filled in to make the curves a little closer to my 4' minimum radius, as it...
Track being laid
The sleepers were painted with Cuprinol to keep the water out and try to prevent rot once I was...
Lyn with mixed stock
It was too nice a day and I couldn't resist getting a few bits and pieces out on the track. Lyn...
Mixed train
What a typical mixed train might look like. The coach is one of four Newquidas which I picked up...
Mixed train
The U class was found at Eurospoor in Utrecht in October 2016. I think every line should have a...
Regards,
Eoin
