FYI...
FALL NEW ITEM: This brand new Pulsed Smoker for Round Boilers combines pulsed steam and cylinder steam functionality in one single unit. The special design with... an outer diameter of only 30mm allows the installation of this unit in round steam locomotive boilers and small ones to. It even fits into the LGB Stainz and Franzburg. The integrated cylinder steam connectors are sealed per factory default and may be used when required. With a brand new designed fan and the optimized airflow this smoke unit makes more smoke than ever. Temperature protection and dry run protection are integrated. It simply connects to track power and operates with DCC speed steps, wheel sensor or clock signal from the Decoder. It may be programmed with CV or POM programming. The scope of supply includes a set of tubes for various installation types. Analog- and Diesel Mode operation are not supported. And the best part: the delivery will begin in mid-September 2016!
SPECIAL OFFER: Introductory price until September 9.!
http://gardenrailoutlet.co.uk/massoth-round-digital-pulsed-smoke-generator
