Well, I am getting close to the moment of multiple decoder purchases plus a programmer and require info on a suitable power supply for the programmer. The Massoth site specifies 14 - 18 volts AC and 16 - 24 volts DC with a 1.5 amp programming current draw.
To date I have only been using my trusty LGB PC programmer for non-sound decoder installs and use my LGB 20 volt AC 6 amp power supply for programming. Now obviously this exceeds the power requirements for the Massoth programmer. Generally I use my Aristo 18 volt DC 10 amp power supply for DCC operation. Is this overkill if used for the Massoth programmer?
Looking through my power supplies I have a computer laptop power supply pumping out a constant 20 volts DC with 4 amp capacity. Would this be more suitable? A friend was told to use (and he does successfully) a locally manufactured 14 volt AC 1.5 amp power supply as the Massoth distributor is concerned with damage being inflicted on the decoder circuitry due 'over powering the chip' (?). 14 volts AC with 1.5 amp capacity is the basic minimum power spec required per the manufacturer power details.
Any suggestions as not only are PC programmers expensive they can be also difficult to source should a replacement be required.
