Zerogee
Clencher's Bogleman
One for Muns, Whatlep or any of the other Massoth experts out there....
If you have a loco (eg: a newer LGB type) with the 10-way DCC interface socket, how do you connect a Massoth LS to it? Can you do so without having to solder any wires direct to the LS board (ie: using only the available plug-in connections)?
Obviously you need the 10-way plug and harness, but I have some spares of those that came with XLS decoders; wiring an XLS to the 10-way connector is straightforward, just follow the manual, but the connections for the smaller LS are not so obvious (and not explicitly covered in the LS manual, as far as I could see).
Thanks in advance,
Thanks in advance,
