frankando12
Hi
I have a Massoth Feedback Module on my system which operates a Passing Siding where one loco would enter one siding pass over a contact then stops , the switches both ends of the loop then change and the loco on the second siding would start it's circuit and return passing over another contact . The switches would again change and the first loco would start. Also on a separate section I had set up a Trolley Set whereby the loco would start from one end of the track then stop at two intermediate stops and at the end of the section would stop and Reverse, stopping at the intermediate sections again and return to it's starting point and the process would start over again for both operations. Both sections worked fine till I decided to install a Piko Booster to my System I was worried about overloading the system. I had the Booster working on the System only for a very short time. I was operating a Switch on the system, when my LGB 55025 Switch Decoder operating the switch had a major Melt Down. This tripped the Boosters overload and the Booster has not been able to be reset and will need to be looked at. I am visiting my daughter who lives in California soon and will take the Booster to Piko San Diego. I have tried set up my system again just using my Piko Central Station. Everything on the system works as it did previous to the Booster being installed except I can not get the Loop and the Trolley set up working . All my track contacts work back to the Feedback Module when tripped, and data cables are communicating between the Module and the Central Station . Is there any way of testing if the Feedback Module is OK or I have a Problem with the Central Station. The Central Station seems to work fine for all other Functions. I wonder what problems have occurred since the Booster Overloaded. I appreciate any suggestion or advice on what I can do to find out the problem.
Thanks Frank
Thanks Frank
