idlemarvel
Neither idle nor a marvel
I've used MASSOTH decoders for years and I'm still puzzled by what they call "load control".
I'm referencing the MASSOTH eMOTION configuration manual.
CV 49 (MASSOTH configuration) bit 1 sets "Digital load control" on, which is the default setting. With this set off, a loco will not move until speed step 4 or 5 is reached for example, the exact speed step depends on the loco. With it set on, the loco will move on speed step 1 afer a short pause. This is what I understand to be "back EMF" in action.
Then we have what MASSOTH call in English "PI-Load control". I don't know what PI stands for; in German is it just called Lastregulung which is the same word used to describe "Digital load control" mentioned above. According to my understanding, it is designed to maintain loco speed when climbing gradients. There are four CVs which adjust this feature (CVs 60-63). I can't test this as I have no gradients on my layout. It can be turned on or off with a function key defined in CV 64.
In the manual section on acceleration and deceleration (CV 3 and 4), the same CV 64 is used to turn the effect of CV 3 and 4 off, so that locos respond immediately to speed step changes, which could be useful when shunting. I suppose this is a side effect of turning on "PI-Load control".
My summary, which I would like some MASSOTH experts on here to confirm is:
1: "Digital load control" is back EMF, is on by default, and can be turned off in CV 49 bit 1
2: "PI-Load control" is (only?) useful if you have gradients (or is it used to fine-tune back EMF?)
3: You can turn off acceleration/deceleration settings using a function key defined in CV 64 (but this will turn on "PI-Load control").
Thanks, Dave
Thanks, Dave
