Maintainse of Lgb Point motoers inside and out
Dinas Bryn
Morning all I am now bring back to life the layout in the garage and outside, inside a cross over works no way only why? outside I have the same nothing works also LGB No 55024 do I have to re-progamme again? look forward to your help Les
Morning all this dry weather has worked in the garden and all points are now working fine so its track cleaning to-day, indoors I still can only get points working one way, I have opened and cleaned were nec but still not working so its back to the old ways Les
Can you feel the motor 'pulse' when going the other way of is it totally dead? If working one way but nothing the other I'd test the actual switch itself and the wiring on it.
I support this idea. Perhaps a wire is loose or one of the diodes fitted by LGB inside the switch unit has blown.
