Locomotive skates - wear
Sarah Winfield
My locomotive's skates are showing signs of wear. I've seen replacements for sale but I wondered if any member had repaired them to avoid having to dismantle the chassis?
I was thinking of some sort of metal "overshoe"..
Your thoughts, printable or otherwise would be appreciated please. (And 'yes' I am a kitchen table modeller)
Thanks,
Sarah Winfield
Sarah, you should be able to easily replace the skates (either old or new types) without having to dismantle the loco chassis. The older type just requires the removal of a screw which is fully accessible without removing anything else, and the newer ones (identifiable by NOT having a screw that holds them in place) can just be "wiggled" out of their fittings. In both cases, the only thing you need to be careful about is not to let the small spring that tensions the skate against the track fly out and get lost - it's a good idea to put something like a wide cardboard box or a washing-up bowl on the table and hold the loco inside said receptacle while you remove the skates, then the springs will hopefully not "sproing" out across the room and disappear forever in an inaccessible corner......
However as you're on a budget and may not want to buy new replacement ones, then yes - you can indeed bend an "overshoe" out of a piece of thin brass strip, and crimp it firmaly in place with some pliers; indeed some people do this deliberately, with the brass strip being narrower than the original skate, to avoid problems with the skates shorting on some metal point frogs when using certain track types (such as Peco code 250) - the narrow brass strip still makes contact where it needs to, but reduces the contact width to avoid the shorting problem caused by the original skate width.
IMHO many skates are replaced because 'they look worn'...
They rub on the track, they will wear.. Only when they wear-through, or start giving problems do they Really need to be replaced.
Worth retelling my experience with skates. Yes, they wore a groove in them. Cost me a new funnel on my O&K after it derailed when the groove argued with some track irregularity
on a layout I was visiting, and took a high dive off the top of the highest embankment on his line.
Removal of the skates was easy, simply take off the bottom cover plate. Now, I took them off to make sure I got the right replacement ones (they do come in different sizes).
Well, the shop didn't have any immediately available, so I reassembled the loco without them. The upside, without skates, the loco would haul 50% more wagons !
Gavin,
That is interesting. I know a lot of people share your view, and remove them, but I really value the skates on my locos and wish other makes, like my Bachmann TTE engines had them.
A cum of mine has silver soldered some of my Playmobil Nickel Silver skates and this really helps to prolong thier life, as replacements for them are just not available.
I find skates really show their value when the plating on a loco's wheelsets begins to wear. Often the smoothness of the pick up quality can deteriorate when this happens, but on skate fitted locos there is usually no loss of smoothness.
James
