funandtrains
Does anyone have a spare set of lift bridge rail clamps? I not sure who makes them but I've been told they exist! Is there a UK shop that stocks them?
I think it's just that Glendale had the last stocks of Hillman clamps.They were Hillman clamps sold it seems exclusively by Glendale Junction who have retired / ceased trading. There was a thread about this recently and no-one was able to suggest an alternative supplier then, maybe someone has looked harder since!![]()
Conversation started Steve.Does anyone have a spare set of lift bridge rail clamps? I not sure who makes them but I've been told they exist! Is there a UK shop that stocks them?
Good idea!I think it's just that Glendale had the last stocks of Hillman clamps.
There is an alternative, which isn't quite as instant lift-out as the Hillman offering, but some Accucraft clamps are split on one side, so you can undo half the clamp and lift out a section while the clamp stays in place connected to the remainder of the track (that's what I use, simply because I had the Accy clamps at the time).
Pretty sure they are Hillman Clamps the not over Fishplate ones. Plenty of these about in UK that appear in small lots now and again at Sows and EBAY. Nice credible alternative solution. Gives the non check book modeller something to think about.After consultation with Steve and inspired by Greg's photo I convinced myself I could knock some up - so here goes.
I don't know who produced the donor clamps but they seemed the most suitable donors from my box of tricks. I made a small brass spacer to fit between the two halves at the drop in end to prevent nipping up too much. The rail is then a snug push-fit. Hopefully the photos will be self-explanatory. I realise it ain't pretty, but it was just an experiment. Any comments or suggestions would be welcome.
View attachment 253828View attachment 253829View attachment 253830View attachment 253831
Strange that you find the Hillman/Glendale Ones a Problem. Been using them around 6 years on my liftout flap to one of my sheds with no issues at all. Well once I got them setup properly that is. Ball bearing needs to be just tight enough to allow retention but not so tight that the Rail will not slot in it with ease.An alternative approach could be to use Massoth / GRS style rail clamps - see pic View attachment 253945
These clip to the rail on one side and then use 2 screws that clamp down on the other. To remove rails from one side of these clamps - e.g. to lift out points (switches) for maintenance - you simply remove the screw holding the rail to be released and just move the rail end outward slightly before lifting it away from the clamp. Refitting is the reverse. Only potential drawback is to avoid losing the screws when you take them out!
I did have some of Glendale's bridge clamps but found them a real pain to use - they wouldn't hold the track in alignment and they never were "lift out". I eventually gave up trying to get them to function "as described" and switched to the normal Massoth / GRS clamps which I've used throughout my layout.
That is a very useful piece of Track. Wish I had thought of that when doing my lift outs. Perhaps if I come across one or two more of them things may get revised.For a friends bridge I used the LGB expansion track. Gives a good power connection.
Ball bearing? What ball bearing?!! None of the 4 I purchased from Glendale had any ball bearings in them. Probably explains why I had difficulty in getting them to work! As Homer S would say, D'OH!!!!
