I always liked the original factory sound on my Sumpter Valley Mallett (when I had it????) and when the opportunity arose to obtain a sound unit for my non-sound Uintah Mallett, I purchased a kit of parts to upgrade the non-sound Mallett to a factory sound version using all original LGB parts. The kit included both boards, clocking device (Hall sensor and axle), bell/whistle reed switch and speaker.
The sound board is marked LGB #20892 which is the Sumpter Valley board (the sound version Uintah board is #20882). The board is set up for MTS. Now my question is what decoder do I fit. At the time I believe a small MTS decoder plus booster decoder was used (circa-2000's). Would a type 3 LGB #55027 or a Massoth XL be suitable utilising the original sound board as just purchased? Where on the board is the decoder installed?
As the original sound was 'serial' (pre parallel upgrade) then I assume multiple function button operations will be needed to get a particular sound function.
First photograph shows the sound board. Second photo is the main circuit board.
