I had a quick look but could not see my posting from the previous forum. A few months ago I purchased a complete sound setup from a new LGB Sumpter Valley Mallett including the wheel sensor a nd bell/whistle trigger switch.
Naively, I assumed that it would be a direct install on my Uintah Mallett as they are basically the same units. Alas, a tale of woe. The sound unit arrived from the States and was installed. Immediately I had a short circuit. I removed the main board and sound board and refitted the stock analogue board and all was well. I informed the seller that I believed the Sumpter main board was faulty and he kindly arranged a replacement main board from Germany.
Well the new board arrived some weeks later and was installed. Alas, the loco shorted out as before. With a little encouragement from a friend I sussed that where the two mottor block connectors attach to the main board they short out with each other. We deduced that if I bypassed the main board connections and hardwired the two motor blocks together then we would avoid the short circuit. Also, applying track power to the two track positive and negative decoder pins on the main board (decoder interface board), then I could obtain sound as well as movement. Unfortunately, I was by this time greatly disillusioned with the whole thing and left it in pieces for several months.
Today, longing for a new project, I once again revisited this catastrophe. I hardwired the two motor blocks together (for the moment I am only interested in analogue operation). I then supplied track power to the track power decoder interface pins on the main board and eventually had success. The loco was reassembled and is now running satisfactorily on analogue.
In time I will disassemble and rewire to fit a Massoth XL decoder and hopefully achieve what I set out to do nearly six months ago. This whole episode has really tested my reserves. I believed it would be a simple install as the unit is decoder interface ready and would just need a decoder fitted to get digital control. Alas, all is not as it seems. When I am happy with the loco I will obtain a decoder and revisit this abomination.
