LGB 'U' class spark arrestor chimney
You will need to say what type - the old screw in type with integrated smoke unit or the new type for the standard 5v smoke unit (loco with plastic valve gear).
A pity as the old type was a standard part held in stock by most dealers.
Have you asked Chalk if they have one?
The old screw-in type that has a nut on the end is much the same as an earlier Stainz except a little taller because of the additional base to the chimney. Interchangeable though.
Perhaps the new type is also similar to the newer Stains locomotives.
