LGB Track very short LGB 10040 Piece andSwitch Boxes still available UPDATE AGAIN
Buy now for 0 USD
SOLD
As new hardy used no box.
LGB Points 1203 Auxiliary Switches 4 of £10 each Post £2.95 UK ONLY but all 4 or multiples could be posted for the same postal rate.
A little tarnished inside but all work ok.
SOLD
LGB 1050U Single rail isolation £10.00 each plus £2.95 postage UK ONLY but all 4 or multiples could be posted for the same postal rate.
A little tarnished some of the connections are faulty but all have enough working connections that test out to be viable units.
LGB 10040 4cm Straight section £2.00 plus £2.95 postage UK ONLY
Well tarnished with a little divit cut out of the one sleeper each side as seen in the picture.
NOW SOLD
LGB 16000 R3 Curves there are 15 full £9.00 each 2 cut bits £7.00 each + £2.95 oer single postage UK ONLY. For multiples of postage you will need to ask as I will need to weigh and sort out.
Enough for a full circle with the two quite long parts but would require 1 to be cut to match existing curves. Tarnished as seen but eminantly cleanable.
NOW SOLD
LGB Left and Right R1 Points. £22.00 each plus £2.95 postage UK ONLY.
Well tarnished with no levers, both have been electrically bonded as in the middle picture.
SOLD Left hander.
Now sold
LGB 1300 30 degree crossover. £30.00 Post £2.95 postage UK ONLY
Sorry but no outside UK offers please, the postage cost is just not worth it to you.
THIS LISTING REPLACES MY PREVIOUS ONE THAT I HAVE NOW SHOWN AS ENDED.
The £20 one has now sold. Faulty 3 switch one still available. 7/3/2019
LGB 51750 Switch Box for operating Points Signals etc x 2 £15 and £20 postage £2.95 each or for both is sold together UK ONLY
One has a faulty Switch hence the lower price of one. THESE do have a side connector so could be used together if required.
right hand point, 30 degree crossing, isolating sections and switch boxes still up for grabs any takers?
BUMP UPDATE. Only Auxilliary Switches, Isolation Rails, very short rail and Switch boxes still available.
