LGB power pickup springs
tramcar trev
I had a similar problem with trolley pole springs.... I found a suitable replacement at my local Hardware shop.... If you specified the spring i.e 3mm od 15mm long compression spring on eBay you may hit gold....
Am about to place a 'Champex' order if you would like some tacked on the end??
