LGB Points and R1 curves wanted please for my loft layout
Hi does any of you have any of this ferreted away that you would like to unload. Points so long as they work that is fine though happy to sort out any dodgy electrics and if no levers that is fine as well as they will be Air Operated. No worries if used outside or even if missing fishplates as I will be using Massoth Clamps.
2 x Right Hand R1 points.
3 x Left Hand R1 points.
5 x R1 curves.
many thanks in advance.
Hi Jon
Yes I have the lot and have sent pm
Mike beat me to it, but I also have some points and curves too....
Thanks Gizzy, may still be in contact as I am thinking of a full R1 Layout due to limitations of Peco points size in the loft. Been messing about with cardboard cutouts and such to see what I can do. I have in the past derided R1 but inside it should be fine with nicely laid flat clean track. Oh and the layout is to be more along the lines of a Tramway so R1 pretty well spot on.
I have spares in R1 curves and points, too, if you need them.
Thanks, am still planning and have some already sorted but will certainly need some R1 points. Will contact you by PM when I know what I need. Think I have curves enough but I am happy to straighten curves for straights so they may be if use as well.
