LGB point blade / tie bar rivets
Cobalt6700
Doing some mods/ repair work to a LGB 3 way and have had to remove one of the point blades.
I have seached high and low for 1.5mm semi-hollow / semi tubular rivets and have only found this place:
Rivet | Semi Tubular Rivets | Clevedon Fasteners
Will get in touch tomorrow, but I have a feeling they are going to want a fairly large order.
Does anyone have a source of the rivets?
I would maybe look to replace with an M1.6 bolt - however the hole drilled in the point blade by LGB is so close to the edge of the blade (0.3mm wall thickness) that I fear a thread will blow it out.
Thanks in advacne :)
Bit fiddly but consider filing down the thread on the bolt where it touches the blade.
Hold the nut on with threadlocker to stop it coming loose.
