Brixham
I have a couple of yellow Cargo Sprinters....they came with onboard decoders which I understand were made by Massoth specially, and not available to buy individually.
Annoyingly, the lights ( headlights and cab light ) are non directional.....on or off. With just another mini ct connector, they could have been directional.
I've been looking for a diagram of the board, I've found this image from another thread where the question was posed 'is this a susi sound output' ( answer no..but massoth susi modules can be made to accept the lgb data format )
So, starting at the top right, the ct connectors are: PLUG ( with red/black cables ), LI-R ( rear light? ), unknown bottom right corner??, SW or is it MS?, above it is SND sound,; crossing to bottom left, that's F1, screw, then LI-F ( front Light ), then LI-F again, then across to the plug with the black and brown cables LI-0. At the lh middle are two pins for smoke.
The lights in the cargo sprinter are in the LI-0 socket. With some work I can split the cab light from the headlight board...so headlight boards fit in LI-F and the cab light in LI-0
Have I got this right?
Malcolm
Malcolm
