stevenfitch
I'm New, Please Be Gentle
Hi
I'm new to G Scale but been using the smaller indoor scales under DCC for years.
I have 2 LGB locos (a Stainz and a 'LOK 1' shunter) and one Aristocraft Dash 9.
I am using Railroad & Co software from Freiwald with Digitrax hardware as i have done for years, i can control the locos but have come across a few issues which i'm hoping someone may be able to throw some light on.
Stainz - Works fine, i can move it back and forward and turn the light on and of using Function 0. I fitted a new LGB recommended decoder to this a few months ago.
LOK 1 - This worked fine using an LGB MTS controller and was on address 3, i never controlled the loco with the PC i just put it straight on the programming track and attempted to change its address to 2 using the Railroad and Co programmer - now the loco will not respond to anything (no movement, no lights) except the horn will sound on Function 1
Dash 9 - I am told by the previous owner that this has 'an MTS decoder fitted'. Looking inside it has a decoder board fitted to the original control board and it works on its address (i forget the address number), however the lights only work on/off via the internal switch and not a decoder function. I am assuming the same is true for the smoke generator which also has a switch, i just have no fluid to test this.
The big question... Is MTS the same as DCC so this should all work or do i just need to strip out the LGB decoders and fit some other true DCC decoders to these... If the second is true then feel free to recommend a decoder brand, id also like some level of 'stay alive' to cope with dirty track and plastic point frogs.
