Lgb mts handset with dimax
No, not directly, but there is a Massoth Interface you can purchase to do this....
I never answered this question as I thought it may be a No but not sure, @Gizzy responded as required. Good luck with your Massoth, good choice. If you have the handsets getting used to them can be a learning process. Key point is to remember that on the screen the bottom line is ery changeable depending on what other keys you have pressed. Once you get the hang of that there will be no stopping you.
No, not directly, but there is a Massoth Interface you can get to do this....
Massoth Part Number for the module is 8138501 Dimax MTS Transducer.
It needs a suitable external power supply from either an LGB Transformer or a other source. I use an old Laptop supply for mine....
