LGB MTS hand control
Dinas Bryn
Evening I have had to replace most of my out door layout due to rotten wood, have done that and I still have a point to rewire outside, I use an old wheel controller for locos in the garage and the buttom P wireless to change points in the garage and outside also for locos outside, all has worked fine till now, old controller work ok but the wireless when I select points shows S putting in the number ie 2 it clears the screen after showing dots, never happened before( I was trying to change a point in the garage, any ideas Les
You may need to reprogram the points decoder Les.
It may have lost its settings.
Or maybe you have wired the point motor wrong.
Sounds like both your Universal and Loco Remores are controlling the locomotives and the wireless system is working.
How many decoders do you have on your layout....
Evening I have spent all day on the layout, I wired the point in the garden, turned on everything, the MTS thought about it, worked the points I had tried to do yesterday and everything is going fine, many thanks for your help Les
