LGB Art.Nr. 22620
Sarah Winfield
My locomotive finally arrived this morning.
On the box is a label "MZS MTS Analogue+Digital ref 22620"
Is there any reason why I cannot use it with my Bachmann EZ digital controller, please?
Thank you,
Sarah Winfield
When you say you cannot use it do you mean it does not move when you place it on the track and apply power? Have you checked the decoder address, it may not be default 3. Try reading the address with your bachmann controller.
I think Sarah's question is really, "Can I use it with my...", Dave.
The simple answer is 'yes'..
The more correct answer is 'it depends..' purely on the address the loco is set to. - You may have to try, this loco only, on your track and see if any of your number keys will select it to run.
Start with address 3
Playmofire, you are quite correct. I have the habit of badly phrasing my sentences. I believe the address of the locomotive is 3.
I've yet to try running it as I'm waiting some information from the seller.
Sarah Winfield
