LGB/ARISTOCRAFT RADII
55.5 said:
Obliged to you kind sir!
They are interchangeable in terms of the number of curves to make a full circle, and when using fishplates.
When using rail clamps, the width of the bottom flat on the LGB rail section is slightly larger than that on the Aristo.
I drew this comparison diagram up about 4 years ago, if it's of any use? It helped me work out where the different manufacturers' trackwork has a near equivalent radius, by using the same colours.
I think I got it about right!
