richarra100
On my dining room table I have the following items;
Transformer 50110
Central Station 55006p
Switch 55025
Handheld with programmer insert 55015
One set of electric points
I connect a loop in the switch between the Prog connection
I connect the Brown wire of the module to the Blue “IN” and the white of the module to the Red “IN”.
I connect the Yellow wire of the module to the Black terminal on the transformer and the Green wire of the module to the White terminal on transformer.
I switch on the power and the programmer displays ....
C - -
I press II and the display changes to...
P - -
I press 1 on the programmer and the display changes to....
d –
I press 1 on the programmer followed by > and the display changes back to....
P - -
I switch off the power. Disconnect the loop and the programme module wires completely.
I connect the Orange and white wire of the points to the switch output “A”.
I connect Red and Blue of the switch “IN” to the central station Red and Blue terminal.
I connect the Black and White between the Transformer and the central station.
I replace the programming module with the normal module in the handheld and plug it into the central station last outlet.
I switch on the power.
Both the transformer and the central station are displaying a green light.
The handheld has only a red light showing.
I press F then 1 and the display shows...
5 –
I press 1.
I press either < or > and each time I press the 5 flashes off but nothing happens to the points.
Why doesn't it work?
Transformer 50110
Switch 55025
C - -
P - -
d –
P - -
5 –
I press 1.
