LGB 50600 450mm Bridge
Halcyon
Does anyone know whether you need to use the bridge mounting set 50611 with this smaller bridge? The information I've found mentions that these bridge mounts are needed with the large 1200mm 50610 bridge but makes no mention of the 450mm 50600. Thanks for any help. Richard.
Not necessary, the 50600 has a near flat base so you can mount it on say a wood or brick end base and run track straight across it.
